02-15-2012, 07:40 PM #1
Floor joist overnotched for plumbing flange
The 11 7/8 I joist is cut at the top about 3 inches wide and about 3 inches down into the joist. Is this a good place for a head out.
02-15-2012, 08:04 PM #2
Re: Floor joist overnotched for plumbing flange
Can't cut the top of I-joists.
02-15-2012, 10:15 PM #3
You need an experienced carpenter to go on the truss manufacturers web, look at the details. There are details of laminating ply wood with a compression space in between the upper and lower flange, then cutting the joist in the way of your trap(I ASSUME) and constructing a box header for the plumbing rough, please dont cut the top and be a ....
If it is a trap is going for a toilet or tub or even a kitchen sink in a island, chances are its next to a partition load of some sort, these are manufactured joist that lock in as a designed system, depending what your looking at, you can create some trouble down the road by thinking its a small piece.
Joseph Ehrhardt
02-16-2012, 04:56 AM #4
The OP was talking about an I-joist, not a truss.
02-17-2012, 08:10 PM #5
I do stand corrected, the I joist manufacturer shows the lamination and framing technique guidelines
Joseph Ehrhardt
