Results 1 to 12 of 12
    Mar 2011
    Corinth, NY
    Default Propane stove vented under deck
    This is vented under a deck attached to the home. It is a mechanical draft from a propane stove in the basement. My common sense tells me this is wrong, but I can't find anything to back it up with. Please help.
    Default Re: Propane stove vented under deck
    Quote Originally Posted by Russell Melville View Post
    As in Free Standing Range you cook on?
    It is wrong, if for no other reason than the 45° down to the termination.
    Agreed.
    As is the Unlisted Installation of the Cap.
    Gas Fired Equipment verses Cooking Appliance would be a Life Limb Safety Issue.
    Cooking could cause some odor and exhaust problems.
    Gas fired Equipment would be a concern for Life Issue.
    Mar 2011
    Corinth, NY
    It is a heating unit, it looks like an iron wood stove but has a gas log inside. It sounds like I have got my answer though. Thank you so much.
    Good Morning Russell,
    Turn the Gas Supply OFF and Tag it for Non Use until the Proper Venting is connected.
    Mar 2011
    Corinth, NY
    Ok, thanks so much. Have a nice day.
    Russ
    Do not turn it off, unless you're a licensed hvac tech.
    Turn Off the Gas Supply " To The Furnace. "
    Do not shut off the gas supply, unless you are a licenced hvac tech.
    I
    I
    OK I'll Bite Raymond.
    What is the Restriction ?
    Oops Glad Raymond Caught This and is Of Course Correct.
    I thought the OP was The Home Owner not a HI and wasn't reading the Thread correctly.
