Results 1 to 14 of 14
Thread: BBQ
    Mar 2011
    Scottsdale, AZ
    Default BBQ
    Does an exterior natural gas bbq enclosure require venting or is it just recommended?
    Default Re: BBQ
    Quote Originally Posted by Greg Hammond View Post
    Too little information to say, but for most, no additional venting is needed.
    Question Re: BBQ
    What do you mean by an "exterior NG BBQ enclosure"? A pic or two would help.
    Note, if it is a listed product, what do the listed instructions say?
    Mar 2011
    Scottsdale, AZ
    Default Re: BBQ
    Okay, let me explain what's going on. I am a general contractor as well as a home inspector, I have a client who I built a guesthouse for several years ago and is in the process of selling his home. He had a home inspection done (not by me) and contacted me to fix the items on his punch list. One of the items on the punch list/inspection report said “ enclosure for gas BBQ is not vented as required”. Now I have never known of any codes for venting exterior built-in gas barbecues while I was building them, and I'm unaware of any as I'm inspecting them. I did some research online and it shows up as a recommendation but I don't see anything that calls out for a requirement (I am not a person who has memorized the code book) . I'm heading up there this afternoon so I can take a picture of it and post it when I get back.
    Thanks!
    Greg
    Default Re: BBQ
    Thanks!
    Greg
    Request the inspector site the code or requirement.
    Default Re: BBQ
    Probably has an enclosed area below the BBQ where the propane tank is stored, correct?
    Mar 2011
    Scottsdale, AZ
    Default Re: BBQ
    Natural gas, fully accessible valve (as required).
    Default Re: BBQ
    Do you have the gas line under the slab? Sleeved and vented line?
    Mar 2011
    Scottsdale, AZ
    Default Re: BBQ
    The gas line comes through the back of the masonry BBQ through a plastic sleeve. The barbecue is not attached to any part of the homes structure it is freestanding with the back of it being a retaining wall for a planter. I think you are talking about a gas line that goes to an interior kitchen island has to be encased inside ABS pipe with a vent. This is a completely different application than that.
    Default Re: BBQ
    Not that different.
    Default Re: BBQ
    The unit is already vented. Those lids are not gasketed air tight. Besides, there is no standard or code requiring 'venting' of freestanding or detached BBQ grilles. If they needed to be 'vented', the mfrs would be required to design and mfr a flue collar and state the approved type, size and configuration of venting.
    Default Re: BBQ
    As said earlier you need to get the inspector to cite the code as related to the problem he pointed out.
    This would be a good way to end some home inspector folklore and become a learning experience since continuing education is not required in AZ.
    Dennis Krouse's Avatar
    Dennis Krouse Guest
    Default Re: BBQ
    If this other inspector wrote "vent as required" then that inspector needs to cite the requirement so everyone is on the same page.
    Georgetown, KY
    Default Re: BBQ
    Damn, that's one hell of a grill!
