    Aug 2009
    Raleigh
    Default horizontal wall crack around perimeter of room
    Inspected a slab house today built in '89 and it had horizontal separation hairline cracks between pieces of sheetrock approximately 3' from floor level all the way around the first floor family room (exterior walls.) Largest gap was approximately 1/64'. House had several other thin cracks above windows and doors and tape separation at wall to ceiling junctions in several areas. Nothing too big but just a lot of them.
    I've never seen horizontal cracking along three exterior walls. No signs of bowing and no significant foundation cracks. Any idea what is going on?
    Default Re: horizontal wall crack around perimeter of room
    Several things can cause that
    Some I can think of are
    Long periods of high humidity
    Drywall screws were over driven
    This will actually cause the drywall to be loose
    Loose drywall will crack at the seams
    Bad tape and mud job
    There are likely many other causes, including foundation problems
    High levels of moisture in the wall (EIFS)
    Oct 2011
    Minneapolis, MN
    This is a pretty good article about cracks in drywall. Improper humidity/temperature control during installation is a strong possibility.
    - James Burgh, 1754.
    May 2010
    No. San Diego Co., CA
    How high was the room? If 11' (approx) the horizontal crack, 3' off the floor is likely poor taping and mudding at a joint. Overall it sounds like a shoddy drywall and taping job, anyway. Cracks around/above windows and doors may because the drywall was pieced, rather than installing larger/full sheets and cutting out the opening once hung. The installer may also have missed studs with screws/nails or even failed to install each joint over a stud/nailing surface. Running a stud-finder over the cracks might have provided some enlightenment.
    There could also be issues with the framing. Hard to tell without being there.
    Oct 2011
    Minneapolis, MN
    It seems significant that all the cracks are on exterior walls (isn't that correct?) I'm betting on expansion/contraction issues with the framing due to change in moisture content. Where are the cracks above ceilings and doors? Horizontal or vertical?
    Aug 2009
    Raleigh
    Some cracks were horizontal, some vertical. Those were very thin in nature. House is a foreclosure and had been vacant for an unknown period of time. Also, the A/C did not cool properly so no telling how long that did not remove humidity.
    Sugarloaf, PA
    Great article, Kristi. Thanks.
    "the relentless pursuit of perfection"
    Feb 2010
    Wenatchee Wa
    Kristi,
    Good article. Thanks for sharing.
    Don Hester
    NCW Home Inspections, LLC
    The limited locations (exterior walls), bad continuous horizontal seam at 3' up on all walls, and occasional lifting at wall-ceiling junctions, seams and areas near windows, are suggestive of water infiltration problems on outside walls, collections of water and moisture issues at floor plates, and crap remediation work for problems due to same.
    Its pretty SOP to R&R to 3' when the wall plates have been saturated and there has been wet insulation and/or mold/mildew issues on the drywall. Avoiding the FB & bracing which might be horizontal, staggered, or herringbone.
    The crap workers don't pull together using blocking transition installed behind the exsisting and dropping down in the cavity to transition and support the seam between the pre-existing sheet and the replacement. Bad tape jobs and repairs elsewhere are also common. Whole job screwy if the area wasn't left open for sufficient time and dries out completely. If home unocupied and unconditioned - repair work won't dry/cure properly either.
    I'd be looking for infiltration/repairs on the exterior, gutter/roof leaks, window leaks, finishing system or sheathing flashing, drainage, defects, checking fire reports, and clue reports, and checking the outlets in the repaired zone, as well as if the area is Wall-to-wall carpet, checking under the carpet and pad at the exterior walls & outside corners.
    Another possiblity at 3' up is removal/replacement of a chair-rail moulding & other moldings elsewhere (carpentry trim) and/or panelized bead-board (nailed and/or glued directly upon prior gyp board?) or other decorative wall finish from the area (might have been poorly DIY installed and unattractive and was removed and refinished less-than-idealy).
