    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Framing in crawl space.
    This is a vague question but I just want to get a few thoughts on this configuration. Home built in 1994, single story, single family. The spot footing looked good although I had questions about the TJI which is being used as a "filler" between the the beams, and the notch.
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    Default Re: Framing in crawl space.
    TJIs are relatively uncharted territory for me, but I doubt that angle connection / termination would be building dept. approved. Since they are an engineered product, I believe you would have to rely exclusively on manufacturer data for allowable uses. Even though electrical galvanized rigid conduit carries a U/L label, it does not mean it can be used for plumbing.
    Ugh. Looking at that is making my eyes hurt. What on earth are they trying to support there? It looks like they dreamed that up on the spot.
    Micket Mouse is alive and building houses in Utah.
    Mickey, Minny, Tom and Jerry templeton the rat
