    Mar 2011
    Canada, Québec, Brossard
    Default What king of piping?
    Duplex 1954, can you help me by telling me what kind of pipe is this?
    Crazy to think it could be an underground oil tank in the basement even though they usually are located outside?
    Thank you.
    Jun 2008
    Default Re: What king of piping?
    It might be an abandoned galvanized water supply line. They tend to corrode from the inside cutting the supply volume. Many times, they get abandoned when an new supply line is installed.
    Georgetown, KY
    From the pictures, I'd guess a galvanized water supply line that's been abandoned, like this one.
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    Definitely threaded, it's rigid steel and most likely galvanized. I've seen what I knew to be called "black iron" pipe used for indoor systems like sprinklers or gas, but never in the ground. So I'm all in w/ my predessors on galvanized steel - - - final answer.
    Mar 2011
    Thanks to everyone.
