Thread: dedicated space
    Default dedicated space
    I call this out when i see it. Do you?
    Robert Meier's Avatar
    Robert Meier Guest
    Default Re: dedicated space
    IMO it should be mentioned. Had a plumber do the same thing to me recently.
    I also would report this. (better safe than sorry) I have seen this 3 times this year and have called it out each time as well.
    Anyone else?
    Andrew Constantine
    Tega Cay, SC Home Inspection Services
    Home Inspection News
    "everything is either living, or dying, there is no middle-ing"
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    By the strict letter of the code you might be correct. However; the waste pipe is non-conductive and not really obstructing access to the panel.
    Apr 2009
    NY State
    Yeah, it's a violation, but as Gary said, it's not doing any harm.
    Besides, both are obviously original, so when the plumber created the violation none of the inspectors caught it or cared.
    If it is called out typically buyers will think your word is gospel. What would you propose be done???
    Nothing, just to be aware that at some point in the future if modifications are made to the pipe in the area of the panel a hazard would be present.
    There will be always be a contractor who says' your Home Inspector should have caught that
    I just let them know
