    Default Aluminum Wire Re-termination
    Does anyone have any information on the availability of aluminum wire re-termination repairs in the Dallas area?
    I have old information from Slocum Electric (now Sanders, I think) but the reports I get through my past clients is that no one is using this process (Copalum) and in the absence of functioning Aluminum wiring repair specialist the electricians seem to be using standard wire nuts to apply a pig tail and not even using anti-oxidant paste in most cases.
    Any information specific to the Dallas or even Texas area would be appreciated. First hand knowledge is even better!
    Sep 2007
    Phoenix, AZ
    Default Re: Aluminum Wire Re-termination
    Take a look at the Alumiconn connector system. It is CPSC approved and a local COPALUM installer in my area has gone to these. Check out AlumiConn Aluminum to Copper Electrical Connectors
    Thanks David, I found these in another thread here last night and they look to be viable although I have not researched the listing, etc.
    brianmiller's Avatar
    brianmiller Guest
    Two questions:
    For aluminum to aluminum pig tail connections , I saw standard NM wire nut connector used that is rated for copper on a house I inspected yesterday. Is there a special aluminum to aluminum wire nut connectors that needs to be used or can you use the copper wire nuts?
    I went to Lowe's/Home Depot, all they had was the purple Aluminum to Copper connector or the standard copper wire nut connectors.
    Brian
    The purple Ideal twist-on connectors are only listed for AL to CU, not AL to Al.
    Any connector used must be listed for use with the conductor materials. Typical wire nuts are not listed for use with AL.
    brianmiller Guest
    thanks jim,
    now, where would one find an AL-AL connector, Lowe's / Home Depot doesn't have 'em!
    b
    The Alumi-conn from King innovations can do AL to AL. They are like a terminal bar arrangement.
    You could also use a split bolt or a Polaris style connector, although you will have a hard time fitting them in the device box.
    Mar 2009
    Colorado Front Range
    Quote Originally Posted by brianmiller View Post
    thanks jim,
    b
    Many of the electrical supply houses around here have then in stock. Big box stores here used to handle them then quit as people didn't know what they were.
    They beat Copalum prices by a substantial margin. They DO require a torque screwdriver for a listed installation - but then a good contractor would have those anyway
