    Default Handy Page for Deciphering Furnace Ages
    I found this while looking up the serial number configuration for a Rudd furnace and thought it would be good to share.
    http://www.abouthomes.info/files/0257%200401.pdf
    Garland, TX
    Default Re: Handy Page for Deciphering Furnace Ages
    Ralph Smith's Avatar
    Ralph Smith Guest
    Barry what a great site!
    Corpus Christi, TX
    Good find, Badair.
    - Paul Fix
    Patrick McCaffery's Avatar
    Patrick McCaffery Guest
    Barry,
    Thank you for this information. I have several like this, but the one you provided seems much more comprehensive.
    May 2010
    St. George, UT
    File- Save As- Thanks! Great reference tools
    Stephen G's Avatar
    Stephen G Guest
    the most research done is probably finding the correct year.
    tks
    Fuquay Varina, NC
    Great links, now all I have to do is remember I have it when I need it. Seems like I book mark so much stuff when it comes time to use it it's easier to Google it.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    Thanks for the resources ! You have induced me to start a Inspection "links" folder. In the interest of sharing, this is probably known to all of you, but, if not, useful.
    http://www.recalls.gov/cpsc.html
    Mesa AZ
    The way I found that works for me to quickly access the references, mfg install specs, and specific code references if needed, is paste and copy them to a documents file, then put the link to the file on my computer screen.
    www.inspectaz.com
