Results 1 to 14 of 14
    Stephen G's Avatar
    Stephen G Guest
    Default Identify type of pipe
    The pipes shown on top of the water tank are everywhere in the house. No signs of leaking.
    Is it plastic, if so, any known problems with these pipes.
    Default Re: Identify type of pipe
    Quote Originally Posted by Stephen G View Post
    Looks like CPVC.
    Chlorinated polyvinyl chloride - Wikipedia, the free encyclopedia
    PVC and CPVC Pipes - Schedule 40 & 80
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    I agree w/ CPVC. Not a fan of epoxy welded joints for water, but it's legal and it does work. At least you have reportable work in that photo.
    Stephen G's Avatar
    Stephen G Guest
    I have only seen it used as the discharge pipe. There was some writing but was illegible.
    Its copper and CPVC mix, must happened when copper prices when crazy way back when....
    Thank you kindly
    Stephen G's Avatar
    Stephen G Guest
    It was common for a few years around 1985 -95. I used it and liked it, but had a few joint failures, like a hose bib that flew across the yard one day. That was from people pulling too hard on the hose. It is a reasonably stable product, and it can stand heat.
    Stephen G's Avatar
    Stephen G Guest
    I think its in the article posted above, they run it for a month in super high temps and p. My read on it is that if it was installed correctly the first time, all things being equal, it should last as decsribed.
    That white sheathed cable coming down in the back is the main ground, its at least 6AWG and connected to the water line. First Ive seen them sheathed. Home built in approx 1958.
    Jul 2010
    Kansas City Missouri
    Also the armored cable needs the proper connector with an anti-short bushing installed.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    Stephen G's Avatar
    Stephen G Guest
    Since the armour went right inside there is no reason for a bushing ...the tank will no doubt be replaced shortly...there were some other issues as well, rusty slurm seeping out of the side and it was installed in 1998. Almost done, budget for replacement.
    Quote Originally Posted by Galen L. Beasley View Post
    Hey Stephen, that tank was installed in '02, per the writing on the lid.
    A bushing is still required there, or rather, a cable clamp. Without the clamp, the armoured flex can be pulled up, exposing the unprotected wires.
    CPVC can go directly to the water heater. That part's OK.
    Stephen G's Avatar
    Stephen G Guest
    John
    I only use the serial # on the the data plate . And yes the wire should be clamped.
    Thanks for the tune up ...
    David Bell's Avatar
    David Bell Guest
    FYI repairs made on CPVC hot water piping need 6 hours to cure before pressurization.
    Stephen G's Avatar
    Stephen G Guest
    Yea; that's what I mean't about by there at least being some reportable work for Steve earlier. I admit to being chemical/s parnoid, but "Chlorinated Polyvinyl Chloride" simply does not sound homogeneous w/ drinking water to me. More like a "go to" ingredient in Dr. Kavorkian's medical bag. Legal and safe are not always the same thing in my personal handbook.
