    Mar 2011
    Lombard, Illinois
    Default Routing of Neutral wires in panel
    Saw this the other day. Neutral wires running under the fuse tracks. Is this OK?. See lower right corner of picture. Thank you in advance for any guidance
    Fidel F. Gonzales
    RELIANT INSPECTION SERVICE
    http://www.reliant-corp.com
    Default Re: Routing of Neutral wires in panel
    That is the mounting rail for the breaker foot. You do not have fuses in that panel.
    As long as the conductors doe not interfere with the breaker mounting there should be no issues.
    Mar 2011
    Lombard, Illinois
    Thank you for your quick response. This is very helpful.
    Fidel F. Gonzales
    Robert Meier's Avatar
    Robert Meier Guest
    Looks OK, overall somewhat sloppy but code compliant.
    Apr 2009
    NY State
    That is a Cutler-Hammer BR series panel.
    That is exactly how I do it. There is a nice "channel" of sorts there where the neutrals can be neatly routed out of the way.
    Mar 2011
    Lombard, Illinois
    Thank so much for your expertise and quick responses. It looked good to me too. But I not and expert on electrical codes. I just wanted to be sure.
    Best regards..
    Fidel F. Gonzales
    Mar 2011
    Lombard, Illinois
    It looked good to me too. But I not and expert on electrical codes. I just wanted to be sure. Thank you so much.
    Fidel F. Gonzales
    Just to satisfy my own curiosity, how is that panel fastned in place? All the apparent fastening locations appear to be unused.
    Egbert Jager
    Diamond Home Inspection
    http://www.diamondhomeinspection.ca
    Robert Meier Guest
    Quote Originally Posted by Egbert Jager View Post
    Since it mounted within a wall I would guess that it's attached to the studs with fasteners on the sides.
    I'm so accustomed to seeing a panel surface mounted and all the wires feeding in from the sides I missed the obvious!!
    Thanks!
    Gonna go grab that coffee now and see if that helps clear the cobwebs
    Egbert Jager
