Thread: what is this?
    Mark Krajcar's Avatar
    Mark Krajcar Guest
    Default what is this?
    White powdery stuff on the cold water copper pipe. My guess is that is mineral deposits from a tiny leak at the joint.
    Default Re: what is this?
    Quote Originally Posted by Mark Krajcar View Post
    Likely, yes
    The cheap brass fitting probably has a pinhole in the casting there.
    Mark Krajcar Guest
    Thank you for the redponses!
    Aug 2011
    I see this constantly around here. Water is "eating" its way out from the inside off the valve. In the past when I was trying to figure out how big a problem these were, I would knock the blisters off. Several times, water started dripping out. It can take many years for these blisters to finally start leaking, but they are still ticking timebombs even if slow ones.
    Mar 2009
    Utah
    When I see these, the brass fitting was probably made in China. I have seen more failures in brass fittings from China than Carter has pills. Spend the extra 50 cents and get one made in America
    May 2009
    Washington State
    Quote Originally Posted by Craig Barr View Post
    Better explain who "Carter" is Craig, there's lots of young'uns on here !
    Utah
    . . . . but they are still ticking timebombs even if slow ones.
    Time-bomb may be a bit harsh.
