Results 1 to 13 of 13
    Sep 2009
    Arizona
    Cool Insulation install oops!
    Found the majority of the attic with insulation installed vapor barrier side up. First install job for the new guy?
    Mesa AZ
    Default Re: Insulation install oops!
    Quote Originally Posted by Rick Goble View Post
    Or, The mfg. made a mistake by not printing the instructions in Spanish.
    www.inspectaz.com
    May 2010
    No. San Diego Co., CA
    Maybe the manufacturer put the vapor barrier on the wrong side...
    The ceiling framing was installed upside down??
    Aug 2010
    BC Canada
    I would double check the insulation underneath. If it were there, I would not worry.
    Exposed Flammable vapor barrier is a cause for concern... but perhaps I missed the point of a tongue-in-cheek comment, no?
    Aug 2010
    BC Canada
    right, but this is in attic, plus the insulation is flammable too.
    Peter,
    Am I understanding you correctly in that you are saying that the exposed facing, which says not to leave exposed because it will burn, is *NOT* a problem?
    Please tell me I am misunderstanding what you are saying.
    Aug 2010
    BC Canada
    Yes, Attic could be extreme hot. Burn hazard, this should be corrected.
    Yes, ...
    Yes to it is not a problem or yes that I am misunderstanding you.
    Aug 2010
    BC Canada
    no misunderstanding, Jerry.
    Peter,
    Peter,
    Now I am really confused.
    a) I understand you to be saying that it is *NOT* a problem.
    b) You say "Attic could be extreme hot. Burn hazard, this should be corrected."
    c) I ask for clarification whether you are saying it is a problem and I am not misunderstanding you, or, that it is not a problem and I am misunderstanding you.
    d) You say I am not misunderstanding you.
    e) (this post) I am not misunderstanding you that it is a) above, that it is *NOT* a problem, or, b) above, that "Burn hazard, this should be corrected."
    a) and b) above are contradictory.
    I will try again, wording it differently:
    1) It is *NOT* a problem and does not need to be corrected.
    2) It *IS* a problem and does need to be corrected.
    Your answer is: _____
    Aug 2010
    BC Canada
    2), Jerry
