    Western Montana
    Default Blue residue on gas shut off valve
    Very pretty shade of blue residue on a gas shut off valve, would guess the gas lines were last inspected in 1959 based on the tag by a nearby furnace. My gas leak detector did NOT indicate a leak (though it did go off when I put it near the draft hood of a nearby 53 year old furnace).
    Wondering what sort of chemical reaction would cause this? Suspect the valve is copper; would it be copper sulfate from condensation?
    Cool Re: Blue residue on gas shut off valve
    Verdigris - Wikipedia, the free encyclopedia
    Someone must have spilled something on it.
    Default Re: Blue residue on gas shut off valve
    Someone sprayed it with soapy water to check for leaks, and didn't clean it off.
    Yep, that is what it looks like....
