    Stephen G Sheldon's Avatar
    Stephen G Sheldon Guest
    Default AC Condensate Line
    Is there a reason why the condensate line from the condensate pump is in pvc? I notice that in some instances the small diameter clear plastic tubing runs all the way to the outside and in other cases the pvc is run all the way to the outside. Just curious as to why the need for the PVC pipe.
    Jul 2010
    Kansas City Missouri
    Default Re: AC Condensate Line
    I have seen a lot of instances where the plastic tube has collapsed or has accidentally been crimped shut causing the A-coil tray to over flow. I assume the main reason to use a rigid pipe is to avoid this.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    mon - friday till 12 pm pvc
    friday after 12pm plastic tube
    Cool Re: AC Condensate Line
    The condensate drainage to the pump is gravity fed (1% grade). This means the slighest restriction such as algae or dirt can inhibit flow whereas the discharge of the pump is under positive pressure so a smaller diameter is allowed. In gravity systems with no pump, it should remain 3/4" pvc the whole way. One notable exception is the secondary heat exchanger, which is almost always a 1/2" rubber hose adapted to 1/2" pvc such as a 3/4 x1/2x3/4 pvc tee in the vertical riser to the pump.
    Rod Smith's Avatar
    Rod Smith Guest
    LOL Wayne! So true....!
    David Bell's Avatar
    David Bell Guest
    Most condensate pumps are sold with a maximum lift which is based on the 3/8 tubing. Using larger diameter materials will drastically reduce the lift capability of the pump.
