    Stanley Chow's Avatar
    Stanley Chow Guest
    Default Hose bibb height
    Is there a minimum height above grade for exterior hose bibbs? I'm thinking of possible siphoning effect.
    Thanks.
    Default Re: Hose bibb height
    NO but it needs a vacuum breaker.
    YES ... the height required for an air gap because you know that atmospheric vacuum breaker is going to be removed ... and because of the closeness of the hose bibb to the wall the air gap may need to be 3 or 4 times the effective diameter of the outlet instead of just 2 times the effective diameter.
    Apr 2008
    Western Massachusetts
    In my area, the anti-siphon devices need to be non-removable. Which means they either need to be integrated into the hose bibb, or they need to be kept in place with a set screw designed such that the head shears off when tightened appropriately.
    Stanley Chow Guest
    Thank you All for your responses.
    Stan
    Quote Originally Posted by Corn Walker View Post
    Yep, same all over, except ... people still take them off.
    Sure, the threads on the hose bibb are somewhat buggered up by that broken off screw, but if they can still get a hose to screw onto it ... so what? (That is what they think.)
