    Nov 2009
    St Paul, MN
    Default Odd furnace vent
    11 year old high efficiency furnace. Intake and exhaust vented out the roof. Furnace is in the basement. The black wrapping on the exhaust vent is insulation. Anyone want to shed some light on this for me?
    I figured the installer wanted to get the exhaust above the second roof for for proper venting, but I'm not sure why they insulated it or brought the intake up so far.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Default Re: Odd furnace vent
    I suspect that installation falls outside the manufactures specs.
    Its also unsightly.
    Nov 2009
    St Paul, MN
    Definitely unsightly but I don't see anything "outside the manufacturer's specs". I just can't wrap my head around wtf the installer was thinking.
    I could, however, see a local AHJ telling the installer that the original installation was too short and needed to be extended above the 2nd roof line and the exhaust vent needed protection from freezing so this is what they came up with.
    Binford Tools's Avatar
    Binford Tools Guest
    Plus whats the deal with the Ell? I could see using a Tee, as just an open on top can allow a leaf to drop in.
    You might be right about the AHJ, but what were they thinking
    This one is not above the second story.
    Aug 2011
    Looks like the installer was concerned about condensation in the exhaust freezing up and possibly restricting or worse the flow of exhaust when very cold. So he wrapped the tube to prevent that........but just a guess.
    I have seen long icicles on occasion hanging from the exhaust tube.
    In any event, it appears to be an unusual installation.
    Binford Tools Guest
    I know your right about the freeze up. With an exhaust that long in the outside air would build up ice with each run cycle.
