Thread: Copings
    dan orourke's Avatar
    dan orourke Guest
    Default Copings
    Default Re: Copings
    Yes.
    Yes, and Yes.
    Default Re: Copings
    Quote Originally Posted by dan orourke View Post
    Thanks, Jerry. Rather than the sealant, how should the interface joints between panels be detailed to prevent leakage, soldered?
    Soldered or a metal crimp lock joint - or both, metal crimp lock joint which is then soldered.
    Mostly though, you only find the soldered joints on copper parapet wall coping caps.
