Thread: Panel
    Sep 2011
    Bolingbrook, IL
    Default Panel
    I found ground wires on the neutral bus. Is this ok since the panel is bonded. This is the only panel
    Default Re: Panel
    Quote Originally Posted by Donald Hobson View Post
    If this is the service equipment, then you are correct. Looks like a main disconnect near the top of the panel.
    Sep 2011
    Bolingbrook, IL
    Default Re: Panel
    Sep 2011
    Bolingbrook, IL
    Default Re: Panel
    Those are Seimens AFCI'. Are they on recall
    Sep 2011
    Bolingbrook, IL
    Default Re: Panel
    Thanks, will look up
