Thread: NEC - Yoke
    May 2011
    Utah
    Default NEC - Yoke
    The NEC uses the term "yoke" several times, but does not define it. Can ayone tell me what the NEC means when it uses this term?
    Merrick Inspections LLC
    Default Re: NEC - Yoke
    Quote Originally Posted by Garrett Merrick View Post
    The "strap" which is part of devices (receptacle outlets, switches, etc.) and which extends out with a top and bottom with holes, and sometimes "ears" which allows the device to be secured to the box the device is installed in.
    A duplex receptacle outlet is actually two receptacle outlets on one "yoke" (on one "strap").
    North Central Texas
    The mounting bracket of a receptacle or switch:
    Texas Inspector
    http://www.texasinspector.com
    Oct 2009
    michigan
    Yoke: The feeling one gets when ones work is inspected by another who is a novice.
