    Jeff Spencer's Avatar
    Jeff Spencer Guest
    Default Found at Today's Inspection
    It's either a light switch or an advertisement for the newest installment in the Harry Potter franchise: "Harry Potter and the 50 Shades of Gray"
    My client, a woman, asked me what I thought about it. The only response I could make while maintaining composure: "Manipulation of the toggle causes movement of excited electrons secondary to induction of electro-motive force"..........
    Default Re: Found at Today's Inspection
    I've seen similar ones. And that's actually Anakin Skywalker from the animated "Clone Wars" TV series.
    Welmoed Sisson
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    Quote Originally Posted by Welmoed Sisson View Post
    Interesting way to turn a guy on ?
    Yesterdays's crawl. Moisture intrusion inspection. That's a 6" pool of water under the open condensate drain. Last picture is directly above position where 4th picture was taken.
    "Contractor" who "rehabbed" the building was present, thinks everything is ducky.
    No-charged the job, and told them if they *really* wanted a complete and detailed list of everything requiring correction, to hire Markus K. to go through it in detail, and write all it up per C of C requirements.
    It's gonna' take *hours*... if you choose to accept...have fun, Markus.
    Anacortes, Washington
    You gotta love those low crawlspaces where they have trenched out a path to access everything. How did they wrestle that Goodman in there? Was it in a larger space?
    //Rick
    Rick Bunzel
    WWW.PacCrestInspections.com
    360-588-6956
    Quote Originally Posted by Rick Bunzel View Post
    //Rick
    Nope. No idea how they did it, especially as that abandoned water heater was blocking the path from the access. I had to kind of slither over it to get to the furnace beyond. At least in Chicago we don't have water-loving venomous snakes in the crawls....
