    Lynn Petrie's Avatar
    Lynn Petrie Guest
    Default OPEN GROUND Defective or Maintenance
    When you encounter a open ground at a receptacle do you rate it as a Maintenance / Repair item or do you write it up as Defective ?
    Why and how come ?
    Default Re: OPEN GROUND Defective or Maintenance
    It's "defective".
    Why?
    Because it's not right.
    If a roof leaks, is it defective or maintenance?
    It's defective.
    Why?
    Because it's not doing its job - it leaks.
    In need of repair.
    Maintenance would be cleaning, painting, and such.
    Grounds don't go bad because they need cleaning, painting or lubricating.
    They are bad/defective and need to be fixed.
    Call it like it is.
