Results 1 to 12 of 12
    Chuck Hill's Avatar
    Chuck Hill Guest
    Default Want to Bid on a Foreclosure but the Roof slopes. major Issue?
    Hello,
    I'm thinking of making an offer on a Homepath home,the property is sold "As is" and on a "Bid Now" option. Now, there is something wrong with the roof, it slopes in the center on both side front and back and exactly in the same area. Looking from the street one side of the roof "sits" lower than the other. I like the location and the inside of the house needs only updates but, I am not a roofer and not sure whether is a"minor problem or something as serious as replacing the entire roof. If I pay for an inspection, and don't win the bid, I will be out a few hundred of dollars, if I do win it would be too late to inspect...winning bidders will have to buy or forfeit earnest money and possibly get sued. Can any one give me an idea as to what may be wrong with this property? I hope I have attached photo of the home correctly, where you see the snow is where it slopes
    Default Re: Want to Bid on a Foreclosure but the Roof slopes. major Issue?
    Quote Originally Posted by Chuck Hill View Post
    Chuck
    Sorry, I can't help
    With all the snow making that call would be difficult for an inspector that is on site.
    I think your gonna have to go it on your own, on this one.
    New York
    Sometimes it's cheaper to go first class the first time, especially if you're bidding to win. The few bucks you save could end up costing alot more later.
    Be careful.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    "Can any one give me an idea as to what may be wrong with this property? "
    Yes ... it has not been inspected.
    I would change one thing in what Steven said ... I would leave off the first word: " it's cheaper to go first class the first time, especially if you're bidding to win. The few bucks you save could end up costing alot more later."
    You are comparing losing a "few hundred of dollars" to (as the saying goes) "losing your shirt" ... it's your choice on which you want to risk.
    Southwest US
    I don't see a problem. The roof is supposed to slope.
    As a home inspector, most foreclosures are foreclosuers for a reason. The owner walked away because the house had problems. I haven't inspected one yet where I thought to myself "what a great deal!".
    END GLOBAL WHINING
    Nov 2009
    St Paul, MN
    If I had to guess, someone took out a bearing wall between the kitchen and living room.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Chuck Hill's Avatar
    Chuck Hill Guest
    Thank you everybody for all the advise. At this point I have a pretty good idea as to how to go about it and most important the amount I should bid. This would be a retirement home and not an investment, will get the inspection and whatever happens happens!
    Chuck,
    Make sure that you get an inspection from someone that has construction and framing experience. One that will quote costs in the report.
    Since you asked for opinions, here's mine. The house is older and has had a few additions. I can't tell from the pics if there is sag in the roof or simply changing planes from additions not matching up.
    We don't know the age or condition of the shingles.
    There may be cracked rafters which will need to be repaired. Difficult but not too expensive to do for a skilled carpenter.
    If the house was built crooked, it may be simply a cosmetic problem, expensive to change.
    If a wall was removed, it should be easy to tell from the interior floor plan. This would be a major expense to repair, not worth it. A home inspection will answer these questions for you.
    The HI should tell you what the house needs, but I don't ever quote prices for repairs in my report. That is a job for a contractor.
    A foreclosure is usually due to an inability to pay the mortgage. It doesn't mean per se the house is a wreck, but it does mean there was no extra cash for maintenance and repairs, probably for several years before the owner had to move out.
    Southwest US
    Really John? You don't see people in your area walking away from homes with major structural issues? Good for you!
    END GLOBAL WHINING
    Not around here either...most foreclosures in Florida are due to mortgages, employment, and cost of living, not structural issues.
    Chuck Hill's Avatar
    Chuck Hill Guest
    John,
    You are correct, the small room and garage was added later, the home was built in 1958.The property is a lake front , 2 acres of land listed at $80,000 where other homes are between 120K 150K. When I went to look at the house (see new pic) I spoke with the next door neighbor he said " the roof has been like that for 20 years" Inside, there are two large water stain on living room carpet, directly below "the slope".The ceiling however was dry but could have been replaced as it is a "drop ceiling" I saw no cracks on walls or ceiling, the basement clean and dry, does not appear to ever had any walls removed. My thought is, if I can get it for an even lower price and I find that the issue is only with the roof it will be worth it.Now the search for a Pro begins, I live in Oh the House is in Michigan...
    Thank you!
