    Oct 2012
    ma
    Default Cracks on the roofing board
    I have noticed multiple cracking lines on my roofing board (attached photos). There is no leaking or anything wrong so far, but I am wondering if the broken board can bear the snow weight as normal, or if it is prone to causing subsequent damage of the shingle and tarpaper above?
    Moreover, if I am going to sell the house, would it be something that inspectors can pick on?
    Thanks!
    Default Re: Cracks on the roofing board
    It is unlikely to ever cause a problem.
    Most likely it was caused by the roofer shooting nails into that big oversized knot in the plank. If there is no sign of a depression on the outside, and you have good quality shingles on your roof, snow will not cause a problem, in my opinion.
    Hater to disagree with you John.
    There is a good potential that snow over time there will be an issue with snow/ice on that section of board.
    The bigger issue may be when someone walks over the broken board and cracks the shingle.
    The fix is easy. Needs to be braced/spliced across the break.
    Aug 2012
    Rock Hill S.C.
    Agreed.
    .......The bigger issue may be when someone walks over the broken board and cracks the shingle.
    The fix is easy........
    Agreed.
    Oct 2012
    ma
    Thumbs up Re: Cracks on the roofing board
    Thank you all for your opinions! That is very helpful.
    Jul 2010
    Wisconsin
    Just curious, is this a new roof? The lumber looks new in the photo, and haven’t seen boards used, in forever. I had the same issue on my house when I bought it and it was never a problem. I just added a 2x to bridge the span so I would not have a soft spot, and just replaced that board when I re-roofed.
