    Jan 2011
    Brunswick, Ohio
    Default extending neutral bus
    Can a double lug be installed in the main service entrance ground connection so at to extend to remote panel? (To avoid double tap)(one conductor under one screw)
    Ben Lomond, CA
    Default Re: extending neutral bus
    Is there no ground bus? Or is the problem fitting the wire into the bus (too large)? The main problem with a double lug, is if it appears as a splice to the inspector. The requirement is for a continuous, unspliced grounding electrode conductor from the grounding point (rod, pipe, rebar tie, etc.) to the main service termination point, usually a grounding bus marked for that purpose.
    Quote Originally Posted by Jose Quinones View Post
    Yes, there are auxiliary bars or lugs that are made for the purpose. This will likely need to come from an electrical supplier (not the big orange box store)
