Thread: A/C disconnect location question
11-21-2012, 01:25 PM #1
I am aware that the A/C disconnect needs to be within sight (and within 50 feet) of the unit. My question is, on a condo building with 6 units, the closest condensing unit in the picture is controlled by the 5th disconnect down. The flexible conduit is buried under mulch etc, so it is not apparent which disconnect goes to what unit.
I see this as a safety issue for the A/C guy who thinks he has this unit disconnected, when in reality he does not.
Is there anything specific, that states the disconnect must line up with unit it is closest to?
Similar Threads:Paul Kondzich
Ft. Myers, FL.
11-21-2012, 01:42 PM #2
Re: A/C disconnect location question
Thanks Robert, actually received a return call from the county electrical inspector. He said the same, as long as they are labled its OK to have them out of order. Thanks again.
Paul Kondzich
Ft. Myers, FL.
11-21-2012, 05:48 PM #3
Yes, as long as the disconnects are marked ... and there is at least 30" x 36" in front of each disconnect ... and ... each condenser unit is marked with the condo unit number (not only to allow matching up the condenser unit and its disconnect, but to allow matching up the condenser unit to the area it serves ... and each condenser unit requires a 30" X 30" service space in front of its service area (mechanical code) ... and each condenser unit requires a 30" x 36" working space in front of its service area where the electrical is located (electrical code) - the two spaces can overlap, so think of the mechanical service space as being the same 30" x 36" as the electrical working space.
11-21-2012, 05:51 PM #4
11-23-2012, 07:57 AM #5
11-23-2012, 08:47 AM #6
11-23-2012, 09:47 AM #7
Call it as you see it. Code aside, if you cannot be certian which disconnect belongs to which unit, the whole purpose of the disconnect and it's proximity is defeated.
