    Default dishwasher drains into laundry tub?
    Here's a question I never thought I'd have to ask:
    If it's ok for a clothes washer to drain into a laundry tub, what about a dishwasher? Anyone ever see such a thing?
    Jul 2010
    Wisconsin
    Default Re: dishwasher drains into laundry tub?
    It’s pretty much a no in the WI plumbing codes. Clothes washers shall discharge via air-break, which could be a sink. But, in our code residential dishwashers can discharge via air-gap or air-break under the counter or above the counter and is pretty detailed about the connections. The only exception that comes to mind off the top of my head is portable dishwashers.
    Southwest US
    Kind of disgusting, but I can't see a problem with it.
    END GLOBAL WHINING
    kitchen sinks, waste grinders, dishwashers and toilets are generally considered black water waste and must be discharged into the sanitary system (continuous contiguous closed direct waste transport connections).
    Aug 2010
    BC Canada
    Why was the DW set up at laundry?
    May 2010
    St. George, UT
    I guess we are looking at the sanitation side of this, but A related problem would be the danger of scalding since most dishwashers heat the water to 140+. Someone using the sink when the dishwasher discharges could be a safety concern.
    Aug 2011
    I usually see this in very old homes. Back in 2008, there was a similar thread about this topic. The problem with these setups is that they rarely discharge above the flood line of the sink.
    The laundry is in the basement directly under the kitchen.
    I would report it as "unconventional" and that unconventional items tend to preform in unconventional ways.
    I think how it is connected depends if your area uses the IRC or UPC. Neither say it is OK to drain directly into a sink.
