	12-13-2012, 10:37 AM #1 Tankless WH Receptacle Cover Plate Tankless WH Receptacle Cover PlateExterior wall-mounted tankless water heater. Receptacle cover plate required to be listed and rated for damp area? In-use type?
 Similar Threads:Texas Inspector
 http://www.texasinspector.com
	12-13-2012, 10:15 PM #2 Re: Tankless WH Receptacle Cover Plate Re: Tankless WH Receptacle Cover PlateThat receptacle outlet is required to be:
 - listed and identified as weather-resistant (WR)
 - listed and identified as tamper-resistant (TR)
 - GFCI protected
 - and if that enclosure is not a raintight enclosure, then the receptacle outlet also needs to have a bubble type cover for it (was there a door over that area, or was it open?)
 That looks recessed into the wall, is the proper wall insulation R-value in the wall behind it?
 That water heater is bottom fed, does it have an atmospheric vacuum breaker installed?
 Is that cord rated for that use?
	12-14-2012, 09:14 AM #3 Re: Tankless WH Receptacle Cover Plate Re: Tankless WH Receptacle Cover PlateThis was not intended to be a duplicate thread. The site chose the very moment I pushed the post button to have a little database experience.
 Texas Inspector
