Results 1 to 12 of 12
    WESTMINSTER CO
    Default who says i cant add more circuits
    great 1959 home today
    need more circuits just call 1-800 idiot
    cvf
    Default Re: who says i cant add more circuits
    Oh come on. It's nothing a little duct tape and some zip strips can't fix.
    WESTMINSTER CO
    left out this gem--never saw this before
    cvf
    cvf
    He gave the circuit a fuse, at least. I can't see where he tapped in for power tho.
    I learned that trick from a sparky when I was in my youth, renting a shack that should have been condemned. A standard lamp socket takes an Edison fuse.
    Charlie,
    You deal wrecker! Its Christmas season how could you be so callous as to call these issues out?
    A lump of coal for you from the real estate agents!
    Southwest US
    You must have some real "gems" in the power company to approve that overhead service. Even the meter reader should have called that out.
    END GLOBAL WHINING
    What meter
    Aug 2011
    Pity the fool that has to change that fuse
    Mar 2011
    Virginia Beach, VA
    Smile Re: who says i cant add more circuits
    Charlie,
    I'm hard pressed to understand the problem. I'm sure you can point the customer to wireless receptacles that you just glue to the wall with a surrounding wrap of waterproof duct tape.
    I think NASA has a bid out for them now. I believe they operate off of random oxygen currents in space inside of the contrail of a passing comet. I also think that each such receptacle has an antenna for it that is about 200' high. You just tape the antenna to the wall. It catches ambient current flow from Califorina Windmills. I think you need to be on the East side of the Applacheian Mountains for you to catch the atmospheric bounce.
    Wallmart may have them soom, the perfect Christmas gift.
    WESTMINSTER CO
    john
    double tapped main service wire--and there is no main breaker--a little sparky you would think
    cvf
    Sep 2009
    rochester ny
    Typical installation for bedouin in the Middle East. You might find the entire neighborhood is wired by the the guy. If your not paying the mortgage or rent why pay for electricity? My recommendation: Add more smoke alarms.
    Darrel Hood's Avatar
    Darrel Hood Guest
    You must be a nit picker. There are still some unused terminals and all the circuits appear to be fused or have breakers. This installation has room for home expansion.
