    Feb 2012
    Pahrump, NV.
    Default Flexible insulated ducting info.
    I'm looking for specific information on flexible insulated ducting. Found a house with silver ducting installed in crawlspace. Ducting is in direct contact with ground, and in a few areas does not have clearance to be raised off ground. I know this isn't acceptable, however would like more specific info. indicating installation and acceptable materials. Thanks!
    Osceola, AR
    Default Re: Flexible insulated ducting info.
    Quote Originally Posted by Scott West View Post
    2009 IRC is all I have available to me at this moment. This help any?
    MI601.4.6 Factory-made air ducts. Factory-made air
    ducts shall not be installed in or on the ground, in tile or
    metal pipe, or within masonry or concrete.
    M 1601.4.7 Duct separation. Ducts shall be installed with
    at least 4 inches (102 mm) separation from earth except
    where they meet the requirements of Section M1601.1.2.
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    Mar 2011
    Sparks,NV
    Scott, I'm not sure what you mean by insulation and acceptable materials. I agree with the ducts should be at least 4" off the ground. This prevents moisture damage and helps keep it from being a highway for pests. Also properly supported ducts will perform better by allowing a smoother pipe for the air to flow reducing static loss. In your area you probably see what I see here which is manufactured homes where the large supply to the other side is laying on the dirt.
    Nevada IOS#1730
    Nevada Energy Auditor #30
    775-342-4767 www.homecsi.com
    Cool Re: Flexible insulated ducting info.
    National Insulation Association
    Insulate Today. Save Tomorrow. : NAIMA North American Insulation Manufacturers Association
    You can probably find some good info. from these two resources that may not be code but industry stds.
    HTH
