Results 1 to 12 of 12
Thread: No access to garage attic
12-27-2012, 08:41 AM #1
This detached garage did not have a means of attic access. Soliddrywall ceiling with no hatchway. I believe the 09 IRC specifes attic access, correct?
12-27-2012, 08:53 AM #2
Re: No access to garage attic
12-27-2012, 09:18 AM #3
Hi Scott, good morning and thank you for you input. That is what I thought also but the way I read the IRC it does not specify. It just says any attic greater than 30 sq feet. Also, there is wiring in the attic, (for lighting). Should not that wiring be accessible? (...maybe not...since wall wiring is not accessible either...).
12-27-2012, 10:04 AM #4
They'll be needing to fix that header over the doorway.
I would say installing an access hatch is advisable and let them decide. It's a 20 minute job if you're slow.
12-27-2012, 10:48 AM #5
And if you want it done right, make it at least an hour's worth of time by a reasonably skilled person.
Did one a few years ago at a former GF's place, and it took me 2+ hours, including building a hinged/insulated hatch cover. Probably spent more than 20 minutes just going up and down the silly step ladder.
But I never claimed to be reasonably skilled.
12-27-2012, 11:01 AM #6
12-27-2012, 11:33 AM #7
Looks like there is a breezeway, could the garage be accessible that way?
It wouldn't be easy or practical but it would possible.
12-27-2012, 06:08 PM #8
12-27-2012, 07:31 PM #9
12-29-2012, 10:51 AM #10
Thanks for all for your comments. The photo was distorted (stretched) due to uploading to insepctionnews. The header is not swayed. There is no attic access through the breezeway, and yes, the headroom exceeds 30 inches.
I think technically that access to this attic should have been provided, but it was not (by the tract home builder).
Appreciate everyones input and have a Happy New Year.
Gene
01-04-2013, 07:54 AM #11
Yep... 30sf of "floor area" and 30" headroom or no required access.
Andrew Constantine
InspectPro Home Inspections
Charlotte NC Home Inspector
11-20-2015, 10:02 PM #12
) looks like camera angle.
