    Matt Barenbrugge's Avatar
    Matt Barenbrugge Guest
    Default furnace/water heater venting together
    I am working on a house where the furnace and hotwater heater are on the same vent. The vent from furnace and water heater are three inch. then they "Y" to a 6-7" double wall which makes sense to go through the floor and roof. Now here is where I am stumped. Above the floor behind a bathroom vanity the double wall reduces to four" then back to 6-7" before going through the attic. Is this OK?
    Default Re: furnace/water heater venting together
    No, not from what I envision.
    Aug 2011
    The short answer is no.
    NO
    Also the original connection may or may not be proper depending on whether the furnace is power vented or not.
