    Jun 2009
    Nashville, Tennessee
    Default Drain line diameter?
    I have been looking and cannot find if there is a size requirement (or recommendation)for a crawlspace floor drain.
    Default Re: Drain line diameter?
    Crawlspace floor drain???
    Ingleside Illinois
    I have a drain in a crawl space but its never seen water. 3 years ago I had an addition put on, a sun room it has a concrete floor under it. The contractor put a drain in using the old window well drain pipe.
    Seemed like a waste but if I ever get water there its pitched toward the drain which is connected to the weeper.
    Jul 2007
    Quote Originally Posted by Bill Wieczorek View Post
    Ok so you have a sump down there .
    I think that should be 2 inches.
