Thread: Boilers
    Dec 2010
    Illinois
    Default Boilers
    Hey guys. I do not see a lot of hot water heating here. However, everytime I do I get a little intimidated. I am wondering where I can get further info and/or training on them. Or steps any of you take to inspect them. Thanks.
    E.D.S
    Home Inspections
    Lic.#450.010534
    Default Re: Boilers
    Obviously lots of info you can find and read at various websites. As starting points:
    - Look at unit before firing if it isn't already running; this is to make sure it looks like it is functional and relatively safe instead of just turning it on and going Oh, __it!
    - once running check and document running temp and water pressure
    - check for auto flow valve and check valve
    - check for auto damper and operation if present, check flue pipe pitch and condition
    - when the unit is OFF look under the boiler to see how heavy the rust flakes are on the floor under the unit
    - check for any signs of dripping under the unit
    - check the burner tubes to see if they have been cleaned
    - check for drips or leaks along pipe runs
    - look for expansion tank
    - as you walk around the house feel the bottoms and tops of radiators for significant temp differences
    - check around radiators bleeders and valves for leaks
    There's lots more but that's it for now. This should get you going.
    Default Re: Boilers
    Add to Markus list:
    - if oil fired burner, operation and function
    ---look for oil leaks
    ---flame appearance: to lean or to rich burn
    Jun 2010
    Vancouver
    Default Re: Boilers
    do NOT test or try the prv to see if it releases. this is something if you open it might not reseal and you will be liable for replacement.(pressure relief valve)
    Default Re: Boilers
    Hello Everybody,
    Two great books by Dan Holohan:
    Hydronic Radiant Heating
    Lost Art of Steam Heat
    You can find them at heating help.com
    Corey
    Dec 2010
    Illinois
    Default Re: Boilers
    Perfect guys. Thanks a lot.
    E.D.S
    Home Inspections
    Lic.#450.010534
