Results 1 to 13 of 13
    Southwest US
    Apr 2009
    NY State
    Default Re: Ingenious way to reduce fire hazard at this Zinsco panel
    PLEASE take the cover off so we can see inside!!
    I am SO curious to see if this is real.
    Fresh juice anyone?
    NoCal
    Great shot Ben in southwest usa.
    Electricity on tap!
    Marshall Brown's Avatar
    Marshall Brown Guest
    I suppose that this gives new meaning to current flow, but at least it couldn't be called a double tap.
    Agreed! Really, really, really need to see a photo of that with the cover off!
    Maybe that is a 'side tap' instead of a double tap?
    Michigan
    That is an older style meter below it, it is designed to catch to overflow of electricity on the top produced by the paddle wheel generator they have hooked up to the river. When the lights are to bright, just crack the valve and the energy flows back to the grid. All about savings eh?
    Everything has its beauty but not everyone sees it.
    Southwest US
    All right but you are going to be disappointed.
    END GLOBAL WHINING
    Apr 2009
    NY State
    DAMN!!
    Well, it all makes sense now ... there was an open knock out and the previous inspection report stated that the open knock out needed to be closed up and sealed - and they had this hose bibb laying around with a bushing which just happened to be the right size for the hose bibb ...
    Just write up a missing bonding clamp and wire to the plumbing and move on.....
    Hose bib is not functioning, have it repaired.
    No one mentioned the missing atmospheric vacuum breaker ...
