Results 1 to 15 of 15
    Mesa AZ
    Default Can you solve this
    Water, ginger ale, and applesuace freezes solid in our frig. door, these items do not freeze in the frige it's self.
    Butter, milk, juices and a lot of other things do not freeze.
    www.inspectaz.com
    Default Re: Can you solve this
    It is all about air flow. Namely poor air flow or circulation in the entire fridge, check for missing baffles, dampers, misplaced drawers and the like. Good circulation within the fridge will create a more uniform temperature. Check the fan, door switch, etc. but I'm guessing you have at least some air flow across the coil or the complaint would be different. Check the setting of the thermostat.
    Could be that cold air is just hitting that spot. We have a spot in our frig that does the same, it is on the top shelf on the right side.
    Mesa AZ
    I don't know. The small water bottles are on an upper shelf, the butter in a squeeze bottle and cubes of butter are on the same shelf. The gingerale and jucies are on the bottom shelf. The apple sauce is on a center shelf.
    It just started doing this 2 or 3 months ago. I turned the frig temp down that didn't help.
    www.inspectaz.com
    As others have said, air flow is the reason the door shelf is different than the rest of the box. Specific heat of water is different than that of milk or butter. When I drove an ice cream delivery truck, just out of HS, I know that chocolate ice cream was the last to freeze and the first to thaw. Door shelf would be a good place to keep the beer .
    Have you cleaned/vacuum the coils? Might be like an HVAC unit with dirty coils and it is super cooling.
    We had something shoved against the back of the fridge that was blocking air flow. Food was freezing. Easy fix.
    Garland, TX
    Refrigerator Cold Spots - YouTube
    according to the USDA a maximum temperature of 40 °F should be maintained in the refrigerator. Properly handled food stored in a freezer at 0 °F should be safe.
    Mesa AZ
    No, It's only 18 or so years old. Didn't think about that
    I do recall the cleaning lady calling me 3 or 4 months ago [ apx when we first noticed it,] telling me there was a lot of water on the floor.
    When I got home everything looked OK.
    www.inspectaz.com
    Water on the floor suggest a clogged drain line, could be due to ice or debris. A clogged or dirty condenser coil has the opposite effect, no or little cooling. I had a refrigerator that iced up due to the evaporator fan motor seizing intermittently. Mine was 20 or so years old. I found the fix at the following link: Best Price Finder and Comparison Shopping Online at PriceDepot.net
    Water on the floor is an indication that there is likely dust build-up under the refrigerator as there is a tray which water drains to when the freezer goes into defrost, that water drains down to the tray, where it evaporates before the defrost cycle repeats.
    The drain pan may be full of dust, debris, etc., and the defrost water is overflowing the pan because of the stuff in the pan, or maybe the water is not evaporating away as it should (going into defrost too often?).
    Check the pan behind the removable kick-plate at the bottom of the front of the refrigerator.
    Apr 2008
    Western Massachusetts
    This is a feature on my refrigerator. There's a small port in with an adjustable damper to control the flow of cooled air into the door.
    Your light bulb is not staying on when you close the door. Only on when you open the door to check on it.
    Southwest US
    Personally, I would contact the home inspector that inspected the home. They obviously did not note this or you would not have purchased the home. They may be liabel for at minimum a new refrigerator and possibly a new house. Certainly contact a lawyer as soon as possible.
    END GLOBAL WHINING
    Wife and children have suffered immeasurable stress and have developed chronic health disorders from drinking frozen juice. A summer home in the Bahamas might possibly make their lives bearable, your honor.
