    Gaura Carlson's Avatar
    Gaura Carlson Guest
    Default 'Hi' from new member, former Master Electrician
    Hello everyone!
    I'm a former master electrician from the mid-80's. I stopped doing all forms of electrical design, construction and maintenance about 20 years ago, and now am attempting to take it up again in a limited form.
    It's most definitely not like riding a bicycle!
    I have experience with overhead and underground high-voltage work (15 kV) down to 6 volt d.c. systems used for control; fire alarm systems; telecommunications; residential, commercial and industrial applications, and more.
    I'm located in WV area at present.
    I hope to be of service to all of you.
    Thank you.
    Regards,
    Gaura
    Default Re: 'Hi' from new member, former Master Electrician
    Just a little curious, what were you doing the last 20 years?
    Gaura Carlson Guest
    Hi Garry
    Even at the end of my electrical work, I was evolving into overall project management as a in-house general contractor for a large development company. I eventually just oversaw the electrical dep't. and devoted my time to oversight of the design, planning and construction aspects. I worked overseas for 6 years on a quite large development project that stalled due to a lack of funds [it was a $750 MM project].
    For the last 8 years or so I've been re-building machines part-time.
