    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Floresence Lights
    Colorado Springs, CO
    Default Re: Floresence Lights
    Probably the ballast going out.
    Bruce Breedlove
    www.avaloninspection.com
    Default Re: Fluorescent Lights
    Yes and no, or, if you prefer, "it depends".
    The humming noise is the laminations in the ballast rattling (vibrating) back and forth, the really noisy one you can here the rattling.
    This is due to what are know as eddy currents, but which is a long drawn out explanation - the short of it is that the magnetic fields are not only expanding and collapsing in their intended direction, but there are magnetic currents flowing sideways through the laminations in the transformer/ballast core. When these come loose or are not made tightly enough, you get that hum.
    Cheaper ballasts, as a rule of thumb, are more noisy. More expensive ballasts are typically quieter. This is because, like every thing else, it cost more to make a better product.
    If they are very loud, have someone remove the lens cover, remove the ballast cover, and you will likely find that there is 'tar' dripping out of the ballast, and that the ballast is sometimes very hot - both cause the other, and are indications that the ballast *as seen better days*.
    Jeff Eastman Guest
    Fascinating....so is this a defect to report in the report?
    Michael Larson's Avatar
    Michael Larson Guest
    Also keep in mind that older ballasts may contain PCBs which must be disposed of properly. Read This
    Chad Fabry's Avatar
    Chad Fabry Guest
    To be accurate:
    It's fluorescent lights
    I heard one humming once. It had a wasp inside the lens cover.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Drift Warning !!!
    Rick,
    What 'tune' was it humming?
    ... I just couldn't resist
    Nolan,
    Since you asked,
    I think it was.. BEE My Little Baby by The Ronettes
    Rick
    Quote Originally Posted by Chad Fabry View Post
    To be accurate:
    Chad,
    You noticed, I am sure, that I made the correction in my post?
    Jeff,
    If it's rattling pretty loudly, I'd just write it up and needing to be replaced, if it's not too bad, I'd tell my client about it and advise him that if the noise is bothersome, there are one or more fluorescent lights which may need to be replaced, or maybe just need new ballasts (with those lay-in type lights, you replace the ballast, not the light, not unless something else is dreadfully wrong with the light itself, with cheap work shop type lights, you can by the lights cheaper than you can buy a replacement ballast).
    Is it a defect? Depends. If it really noisy, at the very least *tell* them about it and have them listen to it, only they will know if it's too loud for them. Then note in your report that you had the client listen to several fluorescent lights because of their noise and the client said they were okay. That covers your butt in case they move in and the teachers in the day care center start complaining about it.
    In reality, I never had clients worry about things like that during a commercial inspection, but it's all up to how you managed, or did not manage, their expectations of what you would be doing. Some clients might, if that's what they believe they hired you for. Next thing you know, one of the fluorescent lamps will not come on and they will call you expecting you to replace it 'because you did not tell me it was not working'.
