    brianmiller's Avatar
    brianmiller Guest
    Default handrail question
    Does the top plate on the wall to the right suffice for handrailing or does one need to be attached along the wall?
    Default Re: handrail question
    It is not a graspable handrail. A handrail is needed and needs to fit into a specific size and shape.
    This is a good reference. irc 2006.pdf
    Mike Lamb
    Inspection Connection, Inc.
    Apr 2011
    Bozeman, Montana
    There doesn't appear to be a change in the 2012. 2009 IRC :
    R311.7.7.3 Grip-size. All required handrails shall be of one of the following types or provide equivalent graspability. 1. Type I. Handrails with a circular cross section shall have an outside diameter of at least 11/4 inches (32 mm) and not greater than 2 inches (51 mm). If the handrail is not circular, it shall have a perimeter dimension of at least 4 inches (102 mm) and not greater than 61/4 inches (160 mm) with a maximum cross section of dimension of 21/4 inches (57 mm). Edges shall have a minimum radius of 0.01 inch (0.25 mm). 2. Type II. Handrails with a perimeter greater than 61/4 inches (160 mm) shall have a graspable finger recess area on both sides of the profile. The finger recess shall begin within a distance of 3/4 inch (19 mm) measured vertically from the tallest portion of the profile and achieve a depth of at least 5/16 inch (8 mm) within 7/8 inch (22 mm) below the widest portion of the profile. This required depth shall continue for at least 3/8 inch (10 mm) to a level that is not less than 13/4 inches (45 mm) below the tallest portion of the profile. The minimum width of the handrail above the recess shall be 11/4 inches (32 mm) to a maximum of 23/4 inches (70 mm). Edges shall have a minimum radius of 0.01 inch (0.25 mm).
    Cornish Home Inspections's Avatar
    Cornish Home Inspections Guest
    No, an actual handrail is needed.
    Nov 2011
    Londonderry, NH
    The 2009 IRC in R311.7.7.3 describes the 2 types of handrails. I am attaching the code and commentary. It is from the 2006 IRC but for this it should suffice.code&commentary071212handrail.pdf Strike the last line "Edges shall have a minimum radius of 0.01 inch."
    Quote Originally Posted by Mike Lamb View Post
    Good information with the details.
    Joe Funderburk's Avatar
    Joe Funderburk Guest
    Another one that isn't graspable.
    http://www.google.com/url?sa=i&rct=j...62501290217446
