    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Re: Substance on roof
    Is this some sort of mastic on the roof?
    They tried to seal the screws. Most likely the rubber grommets(if they used them) started to crack and needed replacement. But to save money they just rolled some type of mastic sealant over them.
    Richard Rushing's Avatar
    Richard Rushing Guest
    What Scott stated is exactly what they did.
    Jeff, one of the first issues that one will encounter with a metal roof is the rubber grommets (called elastomeric washers). When these crack (and they will) they can allow leaks to happen.
    That's what they tried to seal up...
    rr
