Thread: Lennox AC age?
    Default Lennox AC age?
    Default Re: Lennox AC age?
    Serial number on separate label ripped off. Unit looks pretty old.
    John,
    IIRC...
    1.) Lennox closed or at least announced their intention (May 1993) to close their Columbus, Ohio A/C Plant in Late 1993 or in early 1994, and to consolidate their Home Heating & Cooling Products manufacturing at their Marshalltown, IA plant;
    2.) I noted the label you photographed indicates the Condensor was manufactured at the Columbus, Ohio Plant;
    3.) The identification mfg label itself format may be of a pre-1991 vintage;
    Considering Nos. 1, 2, and 3, above, leads to my best WAG as to the age of the unit is at least between 19-1/2 and 22 years old, which would put it well beyond its projected useful life, and would be considered inefficient (SEER, etc.) by today's standards.
    Without a serial number, insignia placard, and/or more information, it would be difficult to say more precisely. Did not lookup model number/series production data.
    HTH.
    What is the age of the house?
    60ish.
    Default u
    John
    I was looking at the numbers in the lower right of the data tag
    8- 9791CC
    I think H.G. is on the right track dependent on sequence of those numbers..
    16-20 years of age.
    John,
    IIRC...
    HTH.
    Thanks!
