Thread: A/C Disconnect boxe:
09-29-2007, 12:21 PM #1
Similar Threads:Last edited by Jeff Eastman; 12-11-2007 at 07:12 PM.
09-29-2007, 01:44 PM #2
Re: A/C Disconnect boxe:
While I don't like that, there is no switch or overcurrent device in there, so it's okay.
09-29-2007, 01:46 PM #3
Jeff,
See Mr. Peck above.
09-29-2007, 01:53 PM #4
Mr Peck,
If there are fuse's in the disconnect then it would be an over current device.
09-29-2007, 07:16 PM #5
Re: A/C Disconnect box:
09-29-2007, 07:20 PM #6
Dan,
Those whites look like the neutrals of the black & white circuit passing through. At least that's what I took them to be.
Which is one of the very reasons the whites are required to be "permanently reidentified by painting" or other effective (permanent) means *IF* they are part of a 240 volt circuit and not the neutrals for a 120 volt circuit.
You'd need to ask Jeff if he checked that as we cannot tell from the photo.
09-30-2007, 06:57 AM #7
