    Aug 2011
    Default Grill in Your Fireplace
    I saw this yesterday. A gas grill in a fireplace. This is an early 60's home with a gas conversion in the fireplace. The damper was working and there wasn't an outside gas shutoff so this was a non-complying conversion.
    But you can grill that steak on a cold snowy winter's evening in the comfort of your family room.resized.jpg
    Default Re: Grill in Your Fireplace
    Where was the gas shut off valve or did you not find one at all?
    Aug 2011
    The shutoff for the fireplace was the one that turned the entire house off at the meter!
    Well then, that is a problem!
    Jan 2011
    Guelph,Ontario
    I doubt there would be enough heat to cook a steak in that arrangement
    I like rare please....
    Osceola, AR
    Quote Originally Posted by Harry Janssen View Post
    I have seen these or similar a couple of times. The grill portion in the units that I have seen actually had burners that appeared to be shortened versions of a gas grill burner mounted under the grilling surface. The units I checked actually seemed to put off enough heat to do a good job searing a steak.
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    Aug 2011
    In this case, it appeared that the grill would cook just fine, but I didn't bring along a test T-bone to try it.
