    Christian Tag's Avatar
    Christian Tag Guest
    Default Main line behind electrical system
    Hi everyone,
    Is it legal to have the main drain line passing behind the electrical system ?
    Thank you for your help !
    Default Re: Main line behind electrical system
    I see the old drain line cleanout below the electrical panels. I don't see a shock hazard in those two pics.
    Miguel Morera's Avatar
    Miguel Morera Guest
    The drain is not my worry, the spaghetti wire system does.
    AdvancedHomeInspection.net Miami FL, Homestead FL, Broward FL
    sanjeev supayia's Avatar
    sanjeev supayia Guest
    Quote Originally Posted by Christian Tag View Post
    Hi everyone,
    Should be ok. I seen drain line above the panel in newer townhome.
    SmartChoice Home And Mold Inspections
    Brampton Home Inspections Mississauga Home Inspector Toronto - Home
    W.Va.
    Hi everyone,
    Short answer, not usually. Refer to NEC 110.26 (F)(1)(a) through (F)(1)(d), Dedicated Equipment Space. But, are you doing a home inspection or Code Inspection. In this case what you see is what you get unless there is a hazard.
    Keith
    Oct 2009
    michigan
    [QUOTE=keithsines;222519]Short answer, not usually. Refer to NEC 110.26 (F)(1)(a) through (F)(1)(d), Dedicated Equipment Space. But, are you doing a home inspection or Code Inspection. In this case what you see is what you get unless there is a hazard
    Yes there is dedicated equipment space and there is dedicated work space. As others have stated, I would not concern myself if I were a HI unless you see a hazard. There is concern if piping (especially water) is above electrical equipment. A messy wiring job is not necessarly a hazard, but a DIY job. The NM cable hanging down near pipe in pic is a hazard.
    I would refer to 'electrician evaluation' just to cover butt, because you just know there is some skeletons in them there closets.
