Thread: white substance
    brianmiller's Avatar
    brianmiller Guest
    Default white substance
    I think the white substance around the damper/ on flue is from water coming in from the exterior, but what do you all think? any other possiblity? Or is it something that non consequential?
    - gas log factory fireplace with metal chimney cap.
    Default Re: white substance
    Looks like A Lot of Deferred Maintenance and would recommend a Sweep conduct a Level II Inspection before use.
    Prefab Fireplace located in ----- exhibits signs of heavy use. Contact a competent Fireplace Professional for Inspection and Service before use.
    Move on.
    This doesn't look like an indication of water intrusion. There are no signs of drip marks. Any water dripping down the inside of the flue through the damper would leave signs of puddling on the floor of the firebox.
    ____________________
    Don Putnam
    Austin, Texas
    www.roofconsulting.com
