    Scott Medlin's Avatar
    Scott Medlin Guest
    Default Questionable purlin?
    Hello friends,
    Any thoughts about the left (notched) end of this purlin and the bracing arrangement? Thanks in advance for your input.
    Default Re: Questionable purlin?
    FWIW none.
    I like the notched purlin support rather than a nailed cleat.
    Shall we assume the ceiling joist are running in the same diection as the rafters, otherwise?
    Scott Medlin Guest
    Hi Jerry,
    Thanks for the feedback. I was not wild about brace on the left and was also concerned about the cut-out in the purlin itself on the left end (not a great picture- tight attic to navigate) this in compromising the purlin stregnth- no? Oh, and yes, the ceiling joists are running in the same direction as the rafters. Thanks again.
    Scott Medlin Guest
    Here is a close up of the left end...
    That was the last 2x6, the one the screwed up when cutting rafters.
    I know it exceeds the notching rules, but at least it is not mid-span.
