Thread: Plywood clips
    Daniel Island, SC.
    Default Plywood clips
    What is the requirement for using clips on a 1/2 " roof deck 24 " span dated to 1985. There was none at this house.
    Jim
    Jan 2011
    Guelph,Ontario
    Default Re: Plywood clips
    half inch ply does not require clips at 2 feet OC,but 3/8 ply does at 24 OC.
    Apr 2007
    WESTMINSTER CO
    are you talking about h clips on roof sheathing?
    cvf
    Jim
    As a former contractor, I've done many roofs and never used 1/2" or 3/8/" plywood on 24"centers. I believe code requires 5/8" minimum 24oc. However, I think it's a good practice to use clips with 5/8" decking on 24oc. 1/2"plywood at 16oc is still weak and if you are a 200lb man standing on a joint where the plywood meets, it will give. You may not like the H clips but they are a little bit of insurance.
    Oct 2009
    Portland, Oregon
    Quote Originally Posted by Bruce Conway View Post
    I see lots of attics as a weatherization contractor, where I do all the work. I see only 15/32" plywood sheathing, where I am able to check. Here is a relevant observation in a blog post.
    H-clips - patent granted (to Mr Simpson) in '86, with patents for an earlier 3-legged version in '82.
    H clip - M&O Products, Inc.
    Likely not required in the mid-80's in your area. I would not call it a defect under the circumstances, but I might report the 1/2" plywood on 24" centers as a weakness and move on. First confirming that it really is 1/2" of course.
    BTW, H-clips have a second purpose. They provide a gap between the sheets to allow for swelling.
    Sep 2012
    Calgary, Alberta Canada
    Not Required in Calgary on 1/2" plywood or OSB @24" o/c, but anything less must have
