Thread: Tool Pouch
    Monroe Ga
    Default Tool Pouch
    There was a post on here about 3 yrs ago mentioning a great little vinyl tool pouch with only 3 pockets. It mentioned the companies website. I bought one and its about wore out. If the inspector that posted it remembers that website I'd appreciate him posting it again. I can't find one like it anywhere. There are no tags in mine.
    Feb 2013
    ma
    Default Re: Tool Pouch
    Have you searched Amazon.com for 'tool pouch'? You might recognize it from the many pictured there.
    Andrew Kling's Avatar
    Andrew Kling Guest
    Could you post a picture of the tool pouch? Both front and back as well as dimensions?
    Do you like the vinyl version, or would you have preferred leather?
    It's not vinyl, but I just finished making a tool apron for myself that holds all the small items needed during the inspection. It took me about an hour to whip up, and it will be getting a field test at this afternoon's inspection.
    Welmoed Sisson
    Monroe Ga
    Quote Originally Posted by Welmoed Sisson View Post
    Thanks for the response. Mine was small and i could wear it on my belt. I'll find something comparable.
    Andrew Kling Guest
    Well if you do see fit to post a pic, I can point you to some manufacturers of leather pouches that you might not otherwise find. Though I would just need a reference as to what your really looking for.
    Nov 2011
    Rocky Ford, Co.
    Go to Duluth Trading. They have all kinds of tool pouches, made of fire hose material with leather.
    Nov 2011
    Oregon, USA
    Not exactly sure of the reasoning, wanting to replace a vinyl unit that wore out in only 3 years' of use, with an identical unit. I've been using several well-made pouches for more than 20 years, one all leather and the other reinforced nylon. Both belts they came with are showing a bit of wear, but neither pouch is even close to the end of its service life. And both (especially the leather one) have been heavily used while performing inspection and construction duties.
    Aug 2011
    Nice and with your logo too!
