Results 1 to 2 of 2
    Christian Tag's Avatar
    Christian Tag Guest
    Default Air exchanger no condensation
    Hi everyone,
    The owner said he never has condensation leaking in the pipe when his air exchanger is functional ? Is it normal ? I thought every air exchanger does create condensation !
    Oh and by the way, the filtered air is sent out from the air exchanger in the furnace room, It's usually connected to a ceiling grill. Any problem with that installation ?
    Thanks for your help
    Default Re: Air exchanger no condensation
    Its certainly not installed to manufactures specifications and its the unit is not going to remove and replace stale air through out the house as intended.
