Results 1 to 21 of 21
Thread: A realtor told me....
04-07-2013, 08:16 PM #1
That this type of plumbing connection line should be written up as a defect because they fail. About 90% of newer homes have these type of connections and I have never written them up. Maybe I was absent that day in home inspector school. Anyone else write these up??
04-08-2013, 03:58 AM #2
04-08-2013, 05:51 AM #3
Re: A realtor told me....
I have never seen them "fail". I have seen some poorly installed and leaking. I write them up if there is a problem.
04-08-2013, 06:41 AM #4
That type of supply is pex. Around me in homes they are allowed, but in commercial applications they are not allowed. Chicago allows them as long as the building is less than 3 stories and houses no more than 3 families.
I would tell the realtor, then you would have to write up the new Delta faucets, since they are building their faucets with built in pex supplies.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
04-08-2013, 08:00 AM #5
They are the worse ones, many do crack after some time. Personally, several in my house cracked, I ended up replacing all with the stainless braided type and never had a problem since.
I have seen more problems with homes on municipal water source around my area, no expansion tank, suspect back pressure buildup from water heater causing most of those bursting, but still, see more of this type cracking than any other types, but are allowed in many areas.
04-08-2013, 08:25 AM #6
Maybe she thought it was polybutylene opposed to Pex?
04-08-2013, 09:00 AM #7
Are we sure it's PEX? Even 3/8" PEX is pretty difficult to bend like that. Would have to have pretty thin walls.
04-08-2013, 03:49 PM #8
I don't write them up unless leaking . I have had these in my house for 16 yrs no problem yet
04-08-2013, 07:24 PM #9
Those 3/8" supply risers are pvc and are made specifically for that use. I have never seen one "fail", I have seen them "leak" at the valve end because of improper installation (i.e., not inserted into the nut far enough, using a brass compression ring instead of the nylon ring, not installing the required internal insert, etc.).
Al least that is what I have seen, and not seen (no "failure") in my rather limited lifetime ...
04-09-2013, 08:03 PM #10
If that is not pex, then my continued education classes are wrong, Delta is wrong for telling us they are using built in pex for supply lines.
And these retailers are wrong too. Lasco 24-2008 Water Supply Flex Pex with 3/8-Inch Formed Faucet Cone Washer by 3/8-Inch Tubing by 36-Inch - Amazon.com
Shop Watts 3/8" x 20"L PEX Faucet Supply Line at Lowes.com
GRAINGER APPROVED VENDOR Supply Line, Plastic, Pipe Dia 3/8 In - Water Connectors - 1PPD5|1PPD5 - Grainger Industrial Supply
And finally Watts the manufacture is wrong too.
875 555 3/8 in. x 15 in. Grey PEX Flexible Supply Tube for Basin, Basin Flexible Type - PEX, Brass & Tubular - Watts
04-10-2013, 07:40 PM #11
04-10-2013, 08:56 PM #12
04-11-2013, 06:15 AM #13
04-11-2013, 07:41 AM #14
Well lets look at this another way. Is PVC allowed for water service? In Illinois you can use PVC for cold water distribution, but hot water requires CPVC. So if those plastic supply lines are not pex and are indeed PVC then they do not meet the code for the hot side of the faucet.
04-11-2013, 10:34 AM #15
04-11-2013, 11:30 AM #16
Those pipes are grey plastic. I think we can agree on that much.
The realtor has been told that grey plastic is bad news. End of story.
Those grey plastic hookup pipes are in millions of home doing the job just fine.
PVC is typically hard plastic, PEX is usually soft plastic. I accept PEX as the best answer.
04-11-2013, 01:25 PM #17
04-11-2013, 01:36 PM #18
04-12-2013, 09:14 AM #19
While that is a sloppy installation it is still a legal one. If you read the writing on the supply tube you will see that it clearly says PEX. Those supply lines do have the cone head molded on them and should outlast the faucet they are attached to. The PEX lines that have the slip on cone head should never be used. They can "and do" come off under pressure with undesirable consequences. FYI: Another note is that the ferrule used on the valve end should be the nylon or plastic ones that come with the PEX tubes instead of the copper ones that will get cocked in the fitting and cut the PEX line causing a leak at that connection. Still if it isn't leaking at the time of the inspection, it's not an issue
that needs to be addressed.
- - - Updated - - -
04-12-2013, 10:31 PM #20
Bob, I think you nailed it. The realtor probably thinks it's that grey, opaque stuff (polybutylene) that her favorite H/I pointed out in an old manufactured home some years back, and now everything that is grey and opaque is suspect. But then that's why she's a realtor, and not a home inspector.
04-13-2013, 07:32 AM #21
Thinking about it most of the ones I have seen fail were excessively bent similar to the ones pictured or worse and had cracked in a bend area, but have had a few fail, of course were ones installed around the late 80's.
